wisst ihr ob der Kotflügel einer 50 Special auf eine PK Gabel passt?
hat vllt jemand ein Bild?
Danke
Danke
mit leichten Veränderungen/Anpassungen:
Hello!
I am Joze from Slovenia. I would like to mount fender from VESPA V50-90, PV 125 (look photo bellow) to my PK50. Is it possible?
Can you please answer in english...
Do you have photo of finished project of that pink vespa in your link?
Thanks, Joze
[Blockierte Grafik: http://scooter-center.com/medias/sys_master/8451422255132240.jpg]
This type of mudguard definetely won´t fit plug & play on a PK fork because it is to small. You´ll either have to cut out the mudguard on the right hand side where the shock absorber is located or file/grind down the upper shock mount on the fork to make the smaller mudguard fit over the fork. Also some of the mounting holes of the mudguard have to be redrilled in new positions corresponding to the mounting points of the fork.
But since you´re from Slovenia you might have a different style of fork - in some countries the PK 50 had a fork very similar to the V50 etc. models. Regarding the width of those forks, the mudguard should fit without problems but probably you´ll still have to drill new holes to mount the mudguard.
Die nächsten Tage ist es bei mir soweit mit der Schlussanpassung. Aktuell wurde bei der Stoßdämpferaufnahme ein Stück weggefräst, damit der Koti ganz drauf geht. Heute mache ich einen Adapter damit ich die originalen Löcher des Kotflügels hernehmen kann. Kannst dir gerne am Samstag am Nachmittag anschauen kommen wennst Lust hast.
Thanks for replies!
Labelsucker: that would be great, can't wait it is sunday.
Hope that you succeed. Please let me know, what you'll find out.
Regards, Joze
